1994 Ford Taurus Running Lights Out
MARCI MANCIL
My 1994 Ford Taurus, 120,000, has all headlights,turn signals, blinkers, flashers, back up, and brake lights operational but the actual rear running lights and dash lights are not working. Have replaced interior switch, checked fuses, and all bulbs. Help!! My daughter is using this car at college and needs it to got to her part time job. Thanks. :?
Apr 13, 2006 at 2:26 PM
LOSONE
  • 1,616 POSTS
Sounds like you have a bad multi function sw. (on the column where the light sw is located) or a bad lamp out warning module (if equiped) Good luck
Apr 14, 2006 at 3:53 AM
Suggested Repair
Inspect the steering-column multifunction switch and, if equipped, the lamp-out warning module; replace the faulty component.
Conversation Summary
A 1994 Ford Taurus has working headlights, turn signals, flashers, backup lights, and brake lights, but the rear running lights and dash lights do not work. The owner already replaced the interior switch and checked the fuses and bulbs. The expert suggests a faulty multifunction switch on the steering column or a bad lamp-out warning module if the vehicle is equipped with one.
