1994 Ford Taurus Vehicle Stalls in Hot weather
GEORGETAMAYO
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 122,000 MILES
I have a 94 Ford Taurus. Everything runs really well until the weather gets real hot. (95f+) When the weather is hot, the car will stall after a longer period of driving it. If I let it sit for about a half an hour, it will start back up and run smoothly as if nothing ever happened. I got a ignition module and went to put it in but I cant seem to locate it. Nobody can locate it. Where is the location for the ignition module and what other things could be causing the vehicle to stall? Thanks
Tuesday, June 2nd, 2009 AT 2:14 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Need to know if 3.0L, 3.0L SHO, 3.2L SHO, 3.8 L
Tuesday, June 2nd, 2009 AT 2:20 PM
GEORGETAMAYO
It is a 3.8 V6 GL. It is not a SHO.
Tuesday, June 2nd, 2009 AT 2:33 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Ignition control Modual as your lookig at engine front of car on the bulkhead near the AC accumulator ie. Big can thing. Also camshaft sensor very heat sensitive located on top front of engine about mid engine and lines up with IGM.
Hope this helps
Thanks for donate
Tuesday, June 2nd, 2009 AT 2:52 PM
