1994 Ford Taurus Unable to crank
DADYZGIRL
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 52,000 MILES
I have a 1994 Ford Taurus, and it will not crank. The car is getting gas and the engine is turning over, but I can not get it to crank. I would like to know if my car has a crank sensor and if so the location of it. If not, then what would cause it not to crank. Battery is new.
Sunday, January 24th, 2010 AT 3:46 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Sunday, January 24th, 2010 AT 5:55 PM
