Engine Mechanical problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
possible dead spot on starter panel lights dim when ignition turned on
however could this be a starter relay malfunction
Tuesday, June 22nd, 2010 AT 10:54 AM
MECHANIC
No crank at all/nothing/nada:
Could be one of the following the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good. If it doesn't apply ignore it
