Check around the starter area and its mounting bolts for a loose ground cable
remove nut
remove cable clean stud and tighten and reinstall cable and nut
check ground wire to the relay box by the radiator
good luck
SPONSORED LINKS
Friday, January 2nd, 2009 AT 6:42 AM
