1994 Ford Taurus 6 cyl Front Wheel Drive Automatic 160K miles
Re: 3.8 L Engine. My oil light won't go out and am faced with the possibility of replacing the pump. Since I have had the front cover off and seen that, at least, the pump cavity is an integral part of the front cover, so am I right in assuming that if the cavity is out of dimension that the whole front cover will have to be replaced? In other words, the oil pump cannot be replaced as a unit seaprate from the front cover.
SPONSORED LINKS
Wednesday, April 28th, 2010 AT 9:26 AM
