1994 Ford Taurus loss of pow electrical problem changed wip
S.WEAVER
  • 1994 FORD TAURUS
  • 6 CYL
  • 180,000 MILES
My wife bought a 1994 taurus SHO the wipers didn't work she was told that it is the wiper motor she buys a motor after I told her it's the multi function switch on the colum I install it at her wishes start the car and now the car has electrical problems and still no wipers the volt gauge is all over the place and it will not stay running heater display shows crazy read out go's on and off every part of the electric system crazy idle speed up and down! I think it now needs a alternator. If problem still remains after I change that where should I go? And I am now changing the wiper switch!
Friday, October 9th, 2009 AT 10:13 AM
BMRFIXIT
  • 19,053 POSTS
Check for a good ground
also check battery terminals and make sure they are clean and tight
Saturday, October 10th, 2009 AT 6:53 AM
IM4THEHOPE
Went to start car no power, jumped it, car had rough idle, idle speed up and down no responce to gas pedal, tac meter read at 8000 car was not at 8000 rpm, same eletrical problems, also pushed gas pedal and it died. What ground should I check? Battery and?
Saturday, October 10th, 2009 AT 12:38 PM
BMRFIXIT
  • 19,053 POSTS
Remove battery terminals and clean
reinstall and tighten
charge battery for a good hr and start engine
using a volt meter measure battery volts with engine running
always check fuses 1st
Saturday, October 10th, 2009 AT 12:44 PM
IM4THEHOPE
Test across positive and negitive or positive and ground im in denver, co where are you located
Saturday, October 10th, 2009 AT 1:54 PM
BMRFIXIT
  • 19,053 POSTS
Connect voltmeter red lead to positive side of the battery
black lead to negative side of the battery
start engine and check volts
what do you have for volts with engine running and with engine off
Saturday, October 10th, 2009 AT 2:04 PM
