1994 Ford Taurus Headlight
1994 FORD TAURUS
PORT_0518
1994 Ford Taurus 6 cyl 92,000 miles
I have replaced the headlight light bulb twice. Within a month or two, the light bulb is burnt out. Could it be the wiring or something else?
Feb 28, 2009 at 5:11 AM
JGAROFALO
  • 489 POSTS
There are a couple of things here.....
First, since the bulb is of the Quartz-halogen type, it is IMPERATIVE that you NOT touch the glass with your fingers. Oils from your fingers will cause the bulb to have a very short service life. The bulb must be handled with a clean cloth or paper towel.
Second, if there is condensation on the inside of the headlight housing, this would indicate a compromised seal, and the housing should be replaced. Moisture droplets hitting the hot bulb will cause it to either break or burn out.
Feb 28, 2009 at 11:21 AM
