left headlight out
79,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
HAGARTHEHORRIBLE
Suddenly no left headlight, both high and low, bulb good, ground to light fixture good. no current to left light wires. When turning lights on and off I can hear a click in the engine compartment which I suspect is a relay switch. (right headlight works perfect and all other lights are OK)
Sep 9, 2016 at 3:01 AM
HMAC300
  • 48,601 POSTS
both lights are wired to gether so if right works check red/blk wire to left headlight to see if it is broken/chafed etc. also check ground in front of lh fender apron. if battery is near that ground check to see if ground wire has been corroded away from battery acid.
Sep 9, 2016 at 5:09 AM
