1994 Ford Taurus fuel pump
SAMUELJ21
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 117,000 MILES
I hav just installed new timing belt. It has been sitting for a few years and wondered if the fuel pump may be oxidized and gummed up and cannot get fuel to injectors? I know there is spark forsure. There is no fuel pressure as well. If it is the fuel pump how hard is it to change w/ having to drop the tank?
Saturday, July 10th, 2010 AT 12:51 AM
BMRFIXIT
  • 19,053 POSTS
When 1st key on fuel pump should come on for a minute and you should be able to hear it
if not have to check for power 1st and before dropping the tank
the difficult part is that you maybe dealing with rust other then that should be some what OK to do
but tank must come down for the fuel pump replacement
You can try this also
hit the middle of the tank with a rubber mullet as a helper trying to start the engine
if that get it going fuel pump need to be replaced
Saturday, July 10th, 2010 AT 6:22 AM
SAMUELJ21
My car is the sho model, will that make a difference?
Saturday, July 10th, 2010 AT 7:32 PM
BMRFIXIT
  • 19,053 POSTS
Fuel pump should be the same
Release fuel pressure. Drain fuel from tankif possible. Raise vehicle on hoist. Remove exhaust heat shield. Remove exhaust pipe (if necessary). Remove fuel inlet and return hoses.
Disconnect vapor crossover and filler hoses. Support fuel tank. Remove fuel tank strap bolts. Partially lower fuel tank. Disconnect fuel lines and electrical connector from fuel gauge sender. Remove fuel tank.
Remove any dirt from around fuel pump flange area. Using Fuel Tank Sender Wrench (D84P-9257-A), remove fuel pump locking ring. Remove fuel pump.
Installation
Clean fuel pump mounting flange, fuel tank mounting surface and seal ring groove. To hold new seal ring in place during installation, apply a light coating of Long Life Lubricant (C1AZ-19590-BA) on seal ring.
Install seal ring in fuel ring groove. Install fuel pump and sender assembly. DO NOT damage nylon filter. Ensure locating keys are in keyways and seal ring remains in place.
Using Fuel Tank Sender Wrench (D84P-9257-A), tighten locking ring by rotating ring clockwise until ring stops against stops. To complete installation, reverse removal procedure.
Pressurize fuel system and check for leaks. To pressurize fuel system, turn ignition on for 3 seconds, then turn ignition off. Repeat ignition cycle 5 to 10 times.
Sunday, July 11th, 2010 AT 9:58 PM
