1994 Ford Taurus Drivers Door
BSDE08
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 148,000 MILES
I have a 1994 Ford Taurus GL. Someone worked on the drivers door before I got the car. Now, the door will not open from either the inside or out and when you put the key in it just turns. The lock button will not move. I was able to get the door panel off and can see the mechanism and rods but, can not get it to open. Can you assist with some suggestions?
Friday, November 5th, 2010 AT 6:24 PM
  • 109,885 POSTS
Is the linkage still attached?
Saturday, November 6th, 2010 AT 1:57 AM
BSDE08
Yes the linkage is still attached. The outer handle itself is broke, just the plastic
Saturday, November 6th, 2010 AT 6:29 AM
  • 109,885 POSTS
It is bolted from the inside of the door. The only thing you can do is replace the handle.
Saturday, November 6th, 2010 AT 3:05 PM
