Electrical problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
where is the powertrain control module located & does it control tranny shifting too
Wednesday, April 8th, 2009 AT 5:42 PM
BMRFIXIT
MECHANIC
Powertrain Control Module (PCM) location
3.0L On top right side of firewall.
3.0L SHO On top right side of firewall..
3.2L SHO On top right side of firewall.
3.8L On top right side of firewall.
What do you have for issues
SPONSORED LINKS
Wednesday, April 8th, 2009 AT 6:01 PM
CAB
MEMBER
1 POST
It started by not changing from 2nd gear at all. I chahged speed sensor and that didnt help. I unplugged battery for a while and it started shifting but if you put shifter in low gear (1st) it trys to go in first and reverse. It will go forward but it acts like its in a bind and when you let off the gas it trys to back up. It was doing this before I unplugged the battery. If you put it in drive or overdrive it shifts fine but sometines I think it pulls out from a stop in second gear. Any info would be greatly appreacciated
