2003 Ford Taurus reset check engine light
123,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBEINGR
the check engine came on because i needed to clean the throttle body, which i did now i need to reset the check engine light
Aug 22, 2009 at 2:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most part stores will reset your check engine light with their diagnostic scanner, free of charge. you can also disconnect battery and reconnect 10 minutes later. however, disconnecting battery may reset other things as well such as radio presets , etc...
Aug 22, 2009 at 6:24 PM
