1993 Ford Taurus starting
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICHARDTUTEN
Sister has a 93 Taurus wagon, 3.8l v6. When I turn the key, nothing happens, Haynes manual says it is the starter relay, which makes sense. Problem, I cannot find the relay. Photo only shows the relay itself, not location. Schematic shows the posiitive battery cable going directly to it, but on her car the cable runs to the high amp fuse box in the engine compartment. Have looked on the firewall, both side well panels, no luck,, anyone know where the thing is located. Much appreciated. Thanks,
Rich
Dec 13, 2009 at 10:23 AM
BMRFIXIT
  • 19,053 POSTS
If have one it should about a ft from the battery
if I remember correctly on the inner fender
test the starter and neutral satiety switch
Aug 14, 2019 at 3:47 AM
JEFFTARPO716
there is a fuel supply shut off located in trunk above wheel well. try reseting it!!
