1993 Ford Taurus Does this model have a fan clutch
1993 FORD TAURUS
91,981 MILES • 6 CYL • 2WD • AUTOMATIC
SNNYHANSEN123
My car has overheated twice in the past week,everytime it overheats the powersteering goes out and you have to manhandle the car for it to steer.Once the car cools down it will steer fine.When it does overheat almost all of the anti-freeze has leaked out,but I looked at all of my hoses and they seem to be fine.So now I'm replacing the water pump,the freeze plug and the thermostat,but I heard if you are replacing the water pump that this is the best time to replace the fan clutch9if equipped).So is does this sound like what is wrong with my car and do I need to replace the fan clutch and do I have one equipped?
Jun 27, 2009 at 10:32 AM
JGAROFALO
  • CAR REPAIR CONTRIBUTOR
  • 489 POSTS
[quote:ff1bf9df35="snnyhansen123"]Engine Cooling problem
1993 Ford Taurus 6 cyl Two Wheel Drive Automatic 91981 miles
My car has overheated twice in the past week,everytime it overheats the powersteering goes out and you have to manhandle the car for it to steer.Once the car cools down it will steer fine.When it does overheat almost all of the anti-freeze has leaked out,but I looked at all of my hoses and they seem to be fine.So now I'm replacing the water pump,the freeze plug and the thermostat,but I heard if you are replacing the water pump that this is the best time to replace the fan clutch9if equipped).So is does this sound like what is wrong with my car and do I need to replace the fan clutch and do I have one equipped?[/quote:ff1bf9df35]
Your water pump definitely could be the problem, but do not overlook the condition of the belt, and the tensioner pulley. Both can contribute to the symptoms you describe.
In answer to the fan clutch question, your car does not have a fan clutch. Your fan is electric, and as such does not require a clutch. You may also want to make sure that the fan is operating.
Jun 28, 2009 at 6:42 AM
