U should have battery volts and good ground
10 volts is low and u should be looking for corroded wire high resistence
what do u have for volts at the auto shut off switch
if battery volts check the wire from that to the pump
also check for power at the relay
SPONSORED LINKS
Tuesday, July 22nd, 2008 AT 6:30 AM
