1991 Ford Taurus FUEL?
HANSENHW
Engine Performance problem
1991 Ford Taurus 6 cyl Front Wheel Drive Automatic HIGH miles
CAR SETS FOR 4-5 DAYS BETWEEN STARTUPS. TAKES UP TO 15 MINUTES TO START. FUEL PRESSURE LOSS? CDI COIL BAD?
Nov 18, 2009 at 1:10 AM
JGAROFALO
  • 489 POSTS
[quote:d15575de81="hansenhw"]Engine Performance problem
CAR SETS FOR 4-5 DAYS BETWEEN STARTUPS. TAKES UP TO 15 MINUTES TO START. FUEL PRESSURE LOSS? CDI COIL BAD?[/quote:d15575de81]
Could be fuel pressure loss. Try this:
When you go to start the car, only turn the key to the "ON" position. Listen for the fuel pump to run and then stop. Turn the key back to "off" and repeat this several times before trying to start. If it starts more easily, then your problem is fuel pressure loss. This could be from a leaky injector or injectors, a fuel pressure regulator, or the pump itself.
Nov 18, 2009 at 9:41 AM
