2001 Ford Taurus
HARTLEYKID
  • 2001 FORD TAURUS
  • 6 CYL
  • 131,000 MILES
I checked THE fuel pump pressure? LIKE YOU IT WAS GOOD READ. OK THE PR0BLEM IS THE LOSSING POWER & LIKE NOT GETTING NO GAS ARE WILL NOT ACCELERATE AND ACTING LIKE IT WONT TO CUT OFF. I SHUT THE CAR OFF AND START BACK UP IT WILL RUN FINE. WHAT IS THAT PROBLEM.
WILL THE CRANK SENSOR MAKE IT DO THAT
Friday, October 29th, 2010 AT 8:52 AM
  • 109,885 POSTS
The crank sensor will usually cause it to shut down. Has the check engine light come on?
Tuesday, November 2nd, 2010 AT 8:07 AM
HARTLEYKID
  • 20 POSTS
YES LET ME KNOW WHAT MISFIRING BUT THAT IT
Tuesday, November 2nd, 2010 AT 8:21 AM
  • 109,885 POSTS
Has the engine been tuned up reciently?
Tuesday, November 2nd, 2010 AT 10:10 AM
HARTLEYKID
  • 20 POSTS
The car was tuned up but set up for two years put double platinum plugs & good wires only put 17000 miles on. I TEST WIRE GOING TO THE COILS WITH A TEST LIGHT ONLY ONE LIGHTS UP DO ALL SUPPOSE LIGHTS UP
Tuesday, November 2nd, 2010 AT 10:52 AM
  • 109,885 POSTS
They all should light when the engine is running.
Tuesday, November 2nd, 2010 AT 11:09 AM
HARTLEYKID
  • 20 POSTS
Ok all wirs light up when car is runing so is the pcm some good are do I need to some new coils again
Wednesday, November 3rd, 2010 AT 11:41 AM
  • 109,885 POSTS
When you say they light up, you do mean you are checking it with a test light, correct? They are not arcing, sparking.
Wednesday, November 3rd, 2010 AT 1:41 PM
HARTLEYKID
  • 20 POSTS
Yes I was check wires to the coils with a test light all lights up with car runing
Wednesday, November 3rd, 2010 AT 2:01 PM
  • 109,885 POSTS
One last question. You mentioned the car sat for 2 years. Have you replaced the fuel or is it what was already in the vehicle?
Thursday, November 4th, 2010 AT 7:07 AM
HARTLEYKID
  • 20 POSTS
Yes I replace the gas but half. Of me coils are fire I may need a new coils
Thursday, November 4th, 2010 AT 7:29 AM
  • 109,885 POSTS
THe coild sound fine. My concern is there is still (1/2) old fuel in the tank. That could be causing the problem. Did you drain any of the old out?
Thursday, November 4th, 2010 AT 7:38 AM
