1988 Ford Taurus will not start
130,000 MILES • 6 CYL • FWD • AUTOMATIC
BROKEN TAURUS
I have a 88' ford taurus that will turn over but will not start.I woke up to this problem.I've checked fuses,plugs,fuel pump,timing,and even sprayed ether into the intake port.Is there a way to clean or check the injectors without the car running? Thanks for any tips
Dec 9, 2008 at 9:32 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect spark issue
if it was fuel or injector it would’ve starter when you sprayed it
Did you check for spark
check module and coil
do a compression test
Dec 9, 2008 at 12:24 PM
BROKEN TAURUS
I've got spark,did a compression test too.If someone sabotaged my fuel could that have clogged my injectors or fuel filter/pump? Thanks again
Dec 9, 2008 at 2:19 PM
BMRFIXIT
  • 19,053 POSTS
Just a note :
by spraying either in the intake port
you are bypassing fuel pump and injectors and fuel system
If you have correct timing and firing order
you have good spark and compression
engine should start on the either as you are spraying and stall when you stop
spraying
good luck
Dec 9, 2008 at 10:02 PM
BROKEN TAURUS
If I had a donation for you folks I would gladly do so.I appreciate the prompt responses from you.I will recommend this site. :-)
Dec 10, 2008 at 4:03 AM
