1994 Ford Ranger Click No Start
LORENH
I have a 1994 Ford Ranger with a 2.3L 4cyl. 5 spd. with 153,00 miles. The problem is it won't start, just click. The battery terminals have been cleaned, and the battery checked with a hydrometer and load test. The starter was removed and taken to autozone and checked ok, was reinstalled and all connections cleaned, still same click. Voltage at starter is 12 volts and when in start postion solenoid wire has 12 volts. I'm stumped. All connections are clean and wires look in good condition. Help please.
Just a update. I took starter back off and they retested still showed good. This time I mentioned that they were testing with out it being under load they agreed gave me a new rebuilt starter and it works now Thanks for the answer.
Sep 23, 2006 at 3:12 AM
NOS
  • 320 POSTS
i belive you have a bad starter solenoid but you have to remember to that a starter will spin when a load is put to it out of the truck doesn't always mean the it is good but try the solenoid first. here is one thing you can try. there is two big post on the solenoid one goes to the battery and one to the starter. take a pair of metal handled pliers and jumper the two big post. make sure the truck is out of gear and e-break is set would want you to get run over.( if the motor cranks it is the solenoid ) by doing that your by passing the switch and the solenoid.(NOS) 8)
Sep 23, 2006 at 7:44 AM
Suggested Repair
Replace the starter if it only passes a no-load bench test. Also check the starter solenoid; jumpering the two large solenoid posts with the vehicle secured can confirm whether the solenoid is at fault.
Conversation Summary
A 1994 Ford Ranger with a 2.3L engine clicked and would not crank despite a tested battery, clean connections, and 12 volts at the starter and solenoid wire. The starter passed an unloaded bench test, but an expert noted that this does not prove it is good under load and suggested checking the solenoid first. A replacement rebuilt starter resolved the no-start.
