2002 Ford Ranger Squealing Noise
DAD
2002 FORD RANGER XLT. AUTO TRANS. SIX CYL. THE MILEAGE IS 73813. THERE IS A SQUEALING NOISE THAT GETS LOUDER AS I ACCELERATE..THE NOISE COMES FROM THE BACK OF THE ENGINE TOWARD THE CAB. I NEED TO KNOW WHAT THE PROBLEM IS SO IT CAN BE FIXED. ITS DRIVING EVERYONE CRAZY!!
THANKS FOR YOUR HELP.
May 27, 2007 at 12:28 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the cam position sensor. looks like the distributor, but has a sensor in it instead of cap and rotor. From what I have seen the bushings go bad in the housing causing a "belt squeek" kind of noise. Have it looked at before the problem gets worse, have seen them actually break, leaving the vehicle stuck
May 27, 2007 at 1:31 AM
Suggested Repair
Have the camshaft position sensor inspected. Worn bushings in the distributor-like sensor housing can cause a belt-like squeal and the unit can break, leaving the vehicle stranded.
Conversation Summary
The owner of a 2002 Ford Ranger with an automatic and six-cylinder engine reports a squealing noise that gets louder with acceleration and comes from the rear of the engine toward the cab. The expert says it sounds like a failing camshaft position sensor, whose housing bushings can wear and produce a belt-squeak noise, and recommends inspection before the sensor fails completely.
