1995 Ford Ranger Intermittent No Start
TRUCK9591
I have a 95 Ranger , 150,000 mi , 6 cyl , stick shift.
I have had this problem for a few months, when I turn the key to the on pos. all the insturment lights come on , seltbelt check gage break check eng ect, if they all come on it will start and run perfectly, if all BUT the check eng lite comes on it wont start. if I let it sit all nite the next morn all the lites come on and it starts and runs fine , I have had a new fuel pump and filter put in, the key feels a little sloppy when I put it in but it acts normal, in the wont start mode the starter turns the motor over fine it just wont fire. it does this about every other week, wont start, its been a good truck but this is just wierd, computer scan shows only a egr valve problem and i put a new on on, still have the same problem. Help
Oct 15, 2007 at 2:54 PM
2CARPRO JACK
  • 11,533 POSTS
I would try an EEC relay, it sounds like sometimes the PCM isnt firing up, like the relay isnt working all the time
Oct 17, 2007 at 1:48 AM
Suggested Repair
Test and replace the EEC relay if needed, since intermittent PCM power-up can prevent the engine from firing even though the starter cranks.
Conversation Summary
A 1995 Ford Ranger with about 150,000 miles intermittently cranks but will not start. When it fails, the check engine light does not come on with the other instrument lights; after sitting overnight it often starts and runs normally. A new fuel pump, fuel filter, and EGR valve did not fix it, and a scan only showed an EGR issue. The expert suggested the EEC relay may be failing to power the PCM consistently.
