1997 Ford Ranger Timing Belt Removal Fix
DALE
I am a rookie who, with a more mechanical friend, is replacing the engine head on my 1997 ford ranger (80,000 miles, 2.3 liter, 4 cylinder, two wheel drive) and decided to replace the timing belt at the same time. My problem is that I don't know how to get the belt off. It seems like I have to take off the crankshaft pulley but the manual I bought doesn't tell me how. Can anybody help me?
Jul 8, 2007 at 4:23 PM
CRAIGFL
  • 89 POSTS
I haven't worked on that particular engine but on my 1.9L, I had to take off the crankshaft balancer to put the timing belt on. I had to fashion a puller to do this.
If your belt goes over the water pump, don't not replace it too!
Jul 8, 2007 at 11:45 PM
MERLIN2021
  • 17,250 POSTS
Go to autozone they will let you borrow a harmonic balance puller!
Jul 9, 2007 at 12:10 AM
Suggested Repair
Borrow a harmonic balancer puller from AutoZone to remove the crankshaft balancer/pulley so the timing belt can come off. If the belt drives the water pump, replace the water pump at the same time.
Conversation Summary
The owner of a 1997 Ford Ranger 2.3L is replacing the cylinder head and timing belt but cannot remove the belt because the crankshaft pulley is in the way. A reply says the crankshaft balancer must be pulled off and recommends replacing the water pump if the belt runs over it. The expert advises borrowing a harmonic balancer puller from AutoZone.
