2001 Ford Ranger Engine Knock
BIKEBALD
I have a 2001 Ranger 4.0 liter 4 wheel drive 67k miles. I have a knock/ping on accelleration or when I put it under a strain, like going up a hill. I have had it tuned and no engine codes appeared. The mechanic said that he thought it may just be a fouled injector and ran some cleaner through the intake. Helped a little, but it is back as strong as ever in less than three weeks. Could it be a bad injector, or something else.
Getting frustrated and need some advice.
Feb 19, 2006 at 3:31 AM
GODBEAR839
  • 77 POSTS
HAve you tried either raising the octane of gas you put in it or two trying some octane booster to see if that makes it less/go away. If so It might need to run on a higher octane fuel to not ping. My Uncle wasted a small fortune on a small block ford trying to fix this when all he needed was higher octane gas.
Feb 20, 2006 at 2:26 AM
BIKEBALD
[quote:b7b208da83="godbear839"]HAve you tried either raising the octane of gas you put in it or two trying some octane booster to see if that makes it less/go away. If so It might need to run on a higher octane fuel to not ping. My Uncle wasted a small fortune on a small block ford trying to fix this when all he needed was higher octane gas.[/quote:b7b208da83]
That I have tried. Even used the Sunoco 94 and added the Octane 107 Booster. Still the same. I am about to give up.
Feb 21, 2006 at 8:50 AM
XJETMECH
  • 12 POSTS
Could be the knock sensor
Mar 14, 2006 at 4:58 AM
BIKEBALD
[quote:5c726fa917="xjetmech"]Could be the knock sensor[/quote:5c726fa917]
Where is the knock sensor located?
Mar 14, 2006 at 8:16 AM
PEPPERMRJ
  • 1,158 POSTS
Don't know for sure. If it is a V motor there can be two of them tho. They are very picky about instalatiioon torque. Can't be too tight or too loose or they won't function properly. Need to pick up a manual. Check the links on the blue bar to the left or your local library.
Good luck and let us know, :)
Mar 14, 2006 at 1:29 PM
VQ35DE
  • 8 POSTS
Built up carbon deposits can be the cause of pinging/knocking in many cases. I'd try a good fuel cleaner additive and/or perform a Fuel Air Induction Service and see if that does the trick first.
Feb 6, 2010 at 2:51 PM
Suggested Repair
Higher-octane fuel and octane booster did not stop the ping. Check the knock sensor or sensors on the 4.0 V6, including correct installation torque, and treat possible carbon deposits with a quality fuel-system cleaner or a fuel/air induction service.
Conversation Summary
A 2001 Ford Ranger 4.0L 4WD owner reports knock or ping under acceleration and load, with no codes. A tune and intake cleaner helped only briefly, and higher-octane fuel plus booster made no difference. Replies suggest a faulty or improperly torqued knock sensor, or carbon deposits addressed with fuel cleaner or an induction service.
