low engine temperature
DAVE44
I have a 1992 ford ranger with a 2.3 4cyl. The temp guage will no go into the normal range and it blows only warm heat not hot. I have replaced the thermostat twice, heater core, water pump, hoses, and head gasket. After replacing the water pump temp did run in normal range for a couple of days but then dropped down again. I've taken to a shop to have the radiator flushed and was told flow was good. They played with it for a week even tried removing the fan and blocking the radiator. It still ran cool. Took it to a second shop and was told head gasket. After changing head gasket it seems to run cooler.
Feb 16, 2006 at 11:13 PM
PEPPERMRJ
  • 1,158 POSTS
Not much left to try. Have you tried a good flush. Maybe even a reverse flush. Something in the block impeding the flow?
Good hunting and let us know. 8)
Feb 17, 2006 at 4:45 AM
LOVESCARS
  • 359 POSTS
temperature of the t-stat?
Feb 17, 2006 at 10:37 AM
