1999 Ford Ranger High Pitched Whine
PARK4X4
1999 ford ranger 4x4 90,000 miles, 3.0 liter engine, manual transmission - when the car is moving in 2 or 4 wheel drive, I can hear an unsettling high pitched whining sound. Up until this point I have had only minor problems and no major repairs. Someone told me that virtually all 1999 Rangers have a specific axle or differential problem around 80,000+ miles. Is this true?
Sep 6, 2007 at 1:28 AM
SERVICE WRITER
  • 9,123 POSTS
Not true. haven't seen one yet.
Check your rear u-joint for play. There may be not be any, but while your there, check for rust settiment around the caps on the ujoint.
A piece of hardware may have let go in the brake drum also.
Sep 14, 2007 at 3:23 AM
Suggested Repair
Check the rear U-joint for play and rust sediment around the caps. Also inspect the brake drum for hardware that may have come loose.
Conversation Summary
The owner of a 1999 Ford Ranger hears a high-pitched whine while moving in 2WD or 4WD and asks whether all 1999 Rangers develop an axle or differential problem around 80,000 miles. The expert says that is not true and recommends checking the rear U-joint for play and rust around the caps, plus inspecting the brake drum for loose hardware.
