1999 Ford Ranger Harmonic Balancer Removal Fix
Here is a video that shows how to remove a harmonic balancer, different car but the procedure is the same. If there are no holes you we need a three jaw puller. Also some will slide off with a little force.
https://youtu.be/NZIMNkLxCMA
from Texas.
Also, not damaging the rubber was a good call.
I apologize you did not get a response until now.
I hope this helps and we are trying to get used to a new layout for the web site. So, I hope you will return in the future as responses are generally up within a day. However, there are are a lot of growing pains with the new site layout and we are trying our best to provide the quick responses that we always strive to provide.
Suggested Repair
The crank bolt loosens counterclockwise. Use a long 1/2-inch breaker bar or a good impact to break it loose rather than bumping the starter with a bar on the crank. After the bolt is out, use a harmonic damper or universal puller; a three-jaw puller may be needed if there are no threaded holes. Pull evenly and avoid damaging the rubber damper ring.
Conversation Summary
The owner of a 1999 Ford Ranger 2.5 could not remove the harmonic balancer bolt while replacing the timing belt and asked about thread direction and how to hold the engine. An expert said the bolt comes out counterclockwise and suggested a long breaker bar, including a starter-bump method, which another poster later called unsafe. Later posts about a 1996 Ranger 2.3 said to use an impact or breaker bar, then a harmonic damper, universal, or jaw puller, pulling evenly without damaging the rubber ring.
