1994 Ford Ranger WINDOW REGULATOR
1994 FORD RANGER
150,000 MILES • 4 CYL • 2WD • MANUAL
GMVRANGEL
HOW DO YOU TAKE OF THE DRIVER'S {LEFT} WINDOW REGULATOR?
Dec 22, 2007 at 7:53 AM
MERLIN2021
  • 17,250 POSTS
Some have rivets that must be drilled out, others there are 3 small dimples on the lower part of the door, they must be drilled large enough to fit the 8 mm socket thru to unscrew the bolts....
Dec 22, 2007 at 8:03 AM
