2002 Ford Ranger Lighting Pulse
GREG LAWRENCE
I have a 2002 Ford Ranger XLT, 3.0 ltr V-6, 51,500 miles. The truck runs great. When the lights are on at night I notice a pulse almost like a fast heartbeat in all of the lighting. Headlights, tail lights, dash & interior dome. The truck seems to be idling fine & this problem occurs no matter the enging RPM. The pulse speed doesn't change. Any advice?
Mar 11, 2007 at 12:24 AM
CHEVY22
  • 1,375 POSTS
Hi Greg
It sounds like you may be missing a ground , check your battery cables for corrosion and clean them first and follow all grounds from the battery to make sure they have good clean connections , if the whole lighting system is doing it its gotta be something in that neighborhood
Jim
Mar 11, 2007 at 1:00 AM
Suggested Repair
Inspect and clean the battery cables and all ground connections from the battery, removing corrosion and ensuring tight, clean contact.
Conversation Summary
A 2002 Ford Ranger owner reports a steady pulsing in the headlights, tail lights, dash, and dome light when the lights are on at night. The truck idles and runs well, and the pulse speed does not change with engine RPM. The expert suggests a missing or poor ground and recommends cleaning corroded battery cables and checking all battery ground connections.
