1998 Ford Ranger Brake Lights Out
CRYSTALSDAD
I found my answer...on a 98 ford ranger xlt, if the brake light doesn't work, it may be the bulbs, the brakelight switch or perhaps even a bad pigtail or a short in the system, but.........
I found out by trial and error that if one bulb is defective then both lights will not burn. The cheapest thing first may prove to be the answer.
I found one bad bulb and when it was replaced then they both worked.
Anytime you replalce one side of a dual performing item, just be smart and replace both and let it be a lesson to keep some spare parts in the glove box.
God Bless,
Gary
Oct 15, 2007 at 9:25 AM
BOOTDOG
  • 665 POSTS
first check for a blown fuse, if good replace the lights. if you still have no luck look into a bad brake light switch located on the brake pedal.
Oct 15, 2007 at 10:04 AM
Suggested Repair
Check the brake-light fuse first. If it is good, replace the brake-light bulbs on both sides, since one bad bulb can keep both lights from working. If the lights still fail, inspect the brake-light switch on the brake pedal; a bad pigtail or wiring short is also possible.
Conversation Summary
A 1998 Ford Ranger owner reported that the brake lights would not work and found that one defective bulb prevented both lights from illuminating; replacing it restored both. The owner also mentioned the brake-light switch, a bad pigtail, or a short as possibilities and suggested replacing both bulbs. An expert advised checking the fuse first, replacing the bulbs, and then inspecting the brake-light switch on the brake pedal if needed.
