1993 Ford Ranger Dies, Runs on Ether
AKSHUFFIT
1993 Ford Ranger XLT with 4.0 Litre engine.
My ford ranger just died coming home from work today, my brother is working on it for me. However,
it will start but will not run. When sprayed with either, it will run for a few minutes and die. But will not run for any time without either. What is the fuel pressure suppose to be on this vehicle? :?:
May 31, 2007 at 1:02 PM
RUDPRO
  • 224 POSTS
It should be about 40psi. Attach your gauge, turn the key to run. The pump should turn on for 2 seconds. Watch the pressure gauge. It should hold steady. You may want to check the fuel pressure regulator for a blown diaphram. It has 2 fuel lines on the bottom and a vacuum hose on top. With the engine running, or cranking, take the vacuum hose off. If fuel is squirting out, the regulator is bad.
May 31, 2007 at 6:07 PM
Suggested Repair
Check fuel pressure with the key on; it should be about 40 psi, prime for about 2 seconds, and hold steady. Inspect the fuel pressure regulator for a blown diaphragm: with the engine running or cranking, remove the vacuum hose on top. If fuel comes out, replace the regulator.
Conversation Summary
A 1993 Ford Ranger 4.0 starts but will not keep running unless ether is sprayed into it, then dies after a few minutes. The owner asked for the fuel pressure specification. The expert said pressure should be about 40 psi, should prime for about 2 seconds with the key on, and should hold steady, and recommended testing the fuel pressure regulator diaphragm by removing its vacuum hose while cranking or running.
