Brakes
DOUBLEB4LIFE
  • FORD RANGER
1995 Ford Ranger / 150K miles / 4-cylinder engine
I am having problems with my brakes. One day last wknd, my brakes just wouldn't work. My master cylinder reservoir was empty, and I added brake fluid and bled the brakes only to find that the rear drum brake cylinder was leaking. I replaced the cylinder, no more leak. Only when I bled the brakes again.I was still having problems. The only way I could stop was if I pumped the brake first while driving. If I waited a couple seconds, it just went to the floor again. So I have no pressure. I went ahead and replaced the master cylinder, thinking that was the problem, only to find that wasn't the problem. So now I am here. I have no idea what to do. I checked all the lines, and there are no visible leaks. Somehow I need to fix this, as my truck is all I have. Please someone help me.
Tuesday, October 30th, 2007 AT 9:26 AM
MIKE H R
  • 3,094 POSTS
To me it sounds like the brake system still has air in it, re bleed the system really good. With the resevoir being empty make sure you do all the lines
Tuesday, October 30th, 2007 AT 9:46 AM
