HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Brakes
Drum
2001 Ford Ranger brake diagram
KITEMOM
MEMBER
2001 FORD RANGER
Brakes problem
2001 Ford Ranger 6 cyl Four Wheel Drive Automatic
Where can I find a brake diagram for rear drum brakes?
Saturday, June 14th, 2008 AT 4:21 PM
BLACKOP555
MECHANIC
Brake diagrams of what? hose routing? spring hookup?
try here
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, June 14th, 2008 AT 4:57 PM
KITEMOM
MEMBER
1 POST
Spring hookup
Saturday, June 14th, 2008 AT 5:39 PM
BLACKOP555
MECHANIC
Did you disconect both sides or is one side still in tact? Best to use the other side as it will have the proper colors and such and the diagram I can provide you is black and white and generic you m ight say.
Saturday, June 14th, 2008 AT 10:15 PM
Please
login
or
register
to post a reply.
Related Brake Drum Content
2000 Ford Ranger Rear Drums
I Recently Purchased A 2000 Ranger And When Appllying The Brakes Hard The Truck Pulsates/lunges Mostly In The Rear. Could The Drums Need...
Asked by
mike450
2000
FORD RANGER
VIDEO
How to Remove a Stuck Brake Drum
Instructional repair video
GUIDE
Drum Stuck On Axle Flange
It is common for a brake drum to get stuck on the axle flange due to moisture and heat of the freshly machined metal exposed by the manufacturing process on both the axle...
Brakes
1995 Ford Ranger / 150k Miles / 4-cylinder Engine I Am Having Problems With My Brakes. One Day Last Wknd, My Brakes Just Wouldn't Work....
Asked by
doubleb4life
1 ANSWER
FORD RANGER
I Need A Diagram Of The Rear Brake
I Need A Diagram Of The Rear Brake Drum Fully Assemble And A Diagram Of Fully Disassemble
Asked by
trafalski2
1 ANSWER
1999
FORD RANGER
2001 Ford Ranger Rear Brakes
Brakes Problem 2001 Ford Ranger V6 Four Wheel Drive Manual 97300 Miles What Causes Rear Brakes To Lock Up Occasionally And Pop Wheel...
Asked by
hitn56
1 ANSWER
2001
FORD RANGER
1998 Ford Ranger Shaking In Steering Wheel And Brake...
My Brakes Has Always Been Good. Good Stopping Power, No Noise, And Smooth Stopping. But Recently I Started To Hear A High Pitched Noise...
Asked by
driver2009
1998
FORD RANGER
VIEW MORE
Brake Shoe and Drum Replacement
How to Fix a Brake Pull
