The brakes have just been done and there is no errror code in the computer, other than this feeling at about dead stop the brakes work great, any ideas what may be causing this problem???
1996 Ford Ranger ABS Activates Near Stop
I have a 1996 Ranger 4WD 3.0 auto, when the truck is almost stopped the anti-lock brake motor comes on and the brakes feel mushy and the brake pedal acts like you're in a panic stop.
Sep 30, 2007 at 9:42 PM
IT sounds like an Anti-lock brake issue. The best of troubleshooting this is to monitor the speed sensor with a scanner capable of doing so. Watching for the signals to drop out when the problem happens.
I have seen quite a few speed sensors go bad that is located on the rear differential. The abs unit will see no signal and think that wheel is not moving, but locked up. So it will engage the abs functions.
Sep 30, 2007 at 10:00 PM
Suggested Repair
Monitor the ABS speed sensors with a scanner capable of reading live signals, watching for a signal dropout when the problem occurs. A failed rear differential speed sensor is a common cause: the ABS unit sees no signal, assumes that wheel is locked, and activates ABS near a stop.
Conversation Summary
The owner of a 1996 Ford Ranger 4WD reports that near a complete stop the ABS motor activates, the brakes feel mushy, and the pedal reacts as if in a panic stop. The brakes were recently serviced and there are no stored codes; braking is otherwise normal. The expert attributes this to an ABS issue and recommends monitoring speed-sensor signals for dropout, noting that a bad rear differential speed sensor can make the ABS think a wheel is locked and engage ABS.
