I know ford uses a blower resistor, which I believe is located in the same area as the blower motor. If the resistor has had it, then the motor will nor work properly. As the resistor actually bumps the power up so that you get the higher speed settings. This resistor may be you cause. You may need to get it from a dealer, but I dont think they are that expencive. Good luck and let me know how you get on.
Tuesday, March 30th, 2021 AT 1:56 PM
