1994 Ford Ranger Starter Replacement
LAURIE
How do I change the starter?
Feb 1, 2006 at 8:43 AM
CHEVY350GUY
  • 109 POSTS
first disconnect the battery. raise the vehicle. disconnect wires, but make a note of where they were. there is two bolts that hold up the starter, remove the bolts and the starter will come down. put the new one in. reinstall bolts, and wires in the location they were. reconnect the battery and your done. :D
Feb 2, 2006 at 11:26 AM
Suggested Repair
Disconnect the battery, raise the vehicle, note and disconnect the starter wires, remove the two starter mounting bolts, lower the starter, install the new starter, reinstall the bolts and wires in their original positions, and reconnect the battery.
Conversation Summary
The owner of a 1994 Ford Ranger asked how to change the starter. An expert advised disconnecting the battery, raising the vehicle, noting and disconnecting the wires, removing the two mounting bolts, installing the replacement starter, reconnecting the wires and bolts, and reconnecting the battery.
