'92 Ford Ranger 3.0 With Very Rough Idle
REDRANGER
  • 1992 FORD RANGER
My high mileage Ranger suddenly began idling roughly and making a "whirring noise" around the distributor area two days after I changed the plugs, wires, and filters. It was running like new before the problem occured, and I have triple checked to make sure that I ordered and replaced the plugs/wires correctly. The check engine light comes on intermittently, and it drives well on the highway. Just idles very roughly. Possibly Distributor problem? Never replaced one before.
Friday, January 26th, 2007 AT 6:30 PM
BUBBA_KOSKI
  • 129 POSTS
Not a dist. Problem, your looking at an idle air control valve (IAC)or if its carb. Then your idle mix. Screws need to be configured
Friday, January 26th, 2007 AT 7:19 PM
REDRANGER
  • 5 POSTS
Thank you much for your response. It is a fuel injected Ranger. I guess you're saying that the IAC problem would make that "whirring" kind of noise coming from the distributor area as well as cause the rough idle? Thanks again for the quick respose. Gotta try and take in on the highway this weekend.
Friday, January 26th, 2007 AT 8:00 PM
REDRANGER
  • 5 POSTS
Nope, it wasn't the IAC valve. Just a well hidden vacuum problem. I guess the sound should of been a dead giveaway.
Thursday, February 8th, 2007 AT 1:21 PM
