2005 Ford Ranger ignition fuse blowing
2005 FORD RANGER
89,000 MILES • 4 CYL • 2WD • MANUAL
NEEDADVISE
I have been having trouble with my ignition fuse blowing. I already had my clutch safety switch replaced which had a short but am still having a problem. I am wondering what other common issues could be causing this problem. Thanks for your advise
Apr 6, 2010 at 10:46 AM
2CARPRO JACK
  • 11,533 POSTS
No common things that I have ever come across.Do you have any aftermarket electrical parts in the truck like an alarm? If so have it removed first to be sure there is nothing but the trucks wiring left.Does it blow the fuse at any particular time or just randomly?
Apr 8, 2010 at 7:55 AM
2CARPRO JACK
  • 11,533 POSTS
No common things that I have ever come across.Do you have any aftermarket electrical parts in the truck like an alarm? If so have it removed first to be sure there is nothing but the trucks wiring left.Does it blow the fuse at any particular time or just randomly? Which fuse number is it exactly that is blowing?
Apr 8, 2010 at 7:56 AM
