hi guys, i am having trouble diagnosing a problem. my engine light is on. when i scan for codes it comes up with " bank 1 lean " i am having trouble figuring out what is causing this. the symptoms are: poor fuel economy, engine idle speed is usually too high or it is loping and it lacks the usual power.
any ideas?
i ask this question once before but i recieved an uneducated guess, i suppose.
4.0 L engine in 2003 does not have an EGR valve so the DPFE does not exist. Intake vacuum is ok. PCV is electronic and connections are ok. MAF is clean and fuel pressure is high. TPS checks out as well as IAC.
any ideas would be appreciated
any ideas?
Sep 8, 2008 at 10:16 AM
