Check Engine Light Stays on?
GENE VIDAL
  • 2003 FORD RANGER
  • 4 CYL
  • 30,785 MILES
I have had 2 mechanics look under the hood to see why my "check engine" light is on. Is this a serious condition? What can I do to cure it? There is no evidence that anything is wrong other than the Warning Light. Gas mileage runs about 20-22 mph. I had expected a better mileage than that but still very content with the truck. Would very much appreciate your learned advise.
Gene
Tuesday, January 8th, 2008 AT 4:38 PM
SERVICE WRITER
  • 9,123 POSTS
We need to rear the codes to see what's going on this guide can help us find the codes so we can fix it.
Wednesday, January 9th, 2008 AT 7:09 PM
MICHAEL.B.FRITZ
  • 2003 FORD RANGER
  • 6 CYL
  • 61,000 MILES
Is there a simple fix to this code or a general fix on Rangers with this code? I live in Germany and really don't have alot of resources.
Friday, November 27th, 2020 AT 9:59 AM (Merged)
P0171 Lean A/F mixture
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (Use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (Try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
DLEASURE
  • 2003 FORD RANGER
  • 6 CYL
  • 76,000 MILES
The check engine light came on but the truck seemed to run ok untill yesterday. The battery was dead and it won't rev over 3000rpm while in park or neutral until you drive it, then it runs fine. Also the radio for some reason stopped working at the same time. I replaced the fuses and that didn't help. I am not sure what is related and whats not.
RACEFAN966
  • 5,029 POSTS
Ok first call around to your local parts stores and find one that does a free scan and have them scan you truck, write down the codes and then clear them and get back to me with the codes and we will see what the truck can tell us.
SEATRAX
  • 14 POSTS
  • 2003 FORD RANGER
  • 3.0L
  • VR6
  • 200,000 MILES
Did a complete tune up, plugs, wires, air filter, repaired all vacum leaks. Used a smoker to find leaks. Has high ltft on bank 1 at idle, 18%, other trims are normal, close to 0%, plus or minus 5%. On test drive it bog at full throttle and the check engine light flashes until you stop and let it idle for a few minutes. Engine don't seem to have full power. At idle it has a slight roughness. Think it may be cam positioner sensor. What do you think.
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure with a gauge autoparts rent it
SEATRAX
  • 14 POSTS
Thanks for the come back. I have a fully equiped functioning mechanic work shop. We buy it if need be and only rent if absolutely necessary, like a fork lift, etc.
We checked the fuel pressure yesterday along with what I said before. Just drove the truck and the check engine light comes on for a few seconds after you full accelerste. Pending codes are random misfire and miss on 4, 5, 6 cyls. Just checked the vacuum at idle and is around 18 inc. Now think the cat conv. Is spopped up on the right bank. Runs fine at low speed or low rpm's. Let me know what you think.
Thanks,
Jim
HMAC300
  • 48,601 POSTS
18" is lower than normal but normally a plugged exhaust/cat is normally 15" at idle what is it when this happens. Fuel pressure should be 60-65 key on engine off or running. It should remain with in 10 psi after shutdown for 2 minutes. If fuel pressure is low I would think it would cause psart of your problem. Also check injectiors misfires are a bitch to find as it can be any basic engine problem and or sensors. Check all grommets for being good as well as this can do it.
SEATRAX
  • 14 POSTS
Fuel pressure is 58psi running and slow bleed of after shutdown. Seem to be a slight erratic reading on the b1 sensor 1 o2 sensor.
Just drove the truck again and don't have proper power and scanner reading was again, miss on 4, 5, 6 and random misfire but it runs perfect on the road as long as no full acceleration. Again the LTFT on bank 1 is much higher that the other ST and LT fuel trims. Yes we replaced all bad grommets including the drivers side pvc elbow. All with new parts. Tightened top manifold bolts. Drives like a restricted exhaust but who knows. Guess we will drill the 1/4'' holes in the exhaust tomorrow and see what the gauge reading is. Yes we are still open for other ideas, o2 sensor? Beats the hell out of me.
HMAC300
  • 48,601 POSTS
58 psi is to low even 2 pounds can make a difference replace fuel filter at same time
SEATRAX
  • 14 POSTS
Thanks for the come back. This is fyi, believe it or not, our parts truck is a '97 3.0 ranger with 30 psi fuel pressure and 40psi if you remove the vacuum hose from the regulator. Has been running like that for about a year.
Remove the y exhaust pipe on the 03 ranger and the l side was partially blocked and the cat convs had come apart. Has three cats on that pipe and all were bad. Will replace the y pipe with factory type.
Thanks
BRADMUR
  • 2003 FORD RANGER
  • 6 CYL
  • 60,000 MILES
Truck runs pretty rough at times I plugged in my code reader and reads out 0303 which is #3 cyl. Misfire detected. Could this be a bad coil? Is there a simple way to check this? Thanks
Friday, November 27th, 2020 AT 10:00 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Yes, it could be the coil pack or a few other things. You can pull the coil wire off and see what color the spark is. It should be a Bright Bluish/White.
It could also be the wire the plug itself a vacuum leak.
Check out the link below for more info.....
https://www.2carpros.com/first_things/why_does_my_engine_run_rough.htm
YFZ450RACER
  • 6 POSTS
  • 2003 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 170,000 MILES
I have 2 codes, on eof them is P2196 Lack of HO2S-21 Switching, Sensor Indicates Rich. What would cause this problem. I have replaced my 02 sensor twice as well as the ICM. Also I have a P0132 HO2S-11 (Bank 1 Sensor 1) Circuit High Input. What is this problem. I have had it to the dealer more than once
DOCFIXIT
  • 18,828 POSTS
Hi
Both codes are for HO2S-11 right rear engine in exhaust. P0132 is a short in O2 or harness the P2196 indicates O2 not switching. If that is the O2 you replaced then short in harness to PCM. That would explain why when replaced still shows codes.
Let me know
Thanks for donate
3.0L or 4.0L?
YFZ450RACER
  • 6 POSTS
It is a 4.0L
LA CHANCE2
  • 2003 FORD RANGER
  • 4 CYL
  • MANUAL
  • 67,000 MILES
The engine lite does not come on but the car seems to be getting hot icould it be a problem with the fuse where can I find the fuse for the check engine lite I do not like driving without it working
BLUELIGHTNIN6
  • 16,542 POSTS
Engine light will not illuminate just because the engine overheats. That is what the coolant temperature gauge is for.
LA CHANCE2
Is there not a fuse the light never lights up on most cars it lights up when you start it and then goes off this one never lights up
