Alternator Not Charging
2003 FORD RANGER
EVILPUPPETMASTER
  • 16 POSTS
Electrical problem 6 cyl Four Wheel Drive Manual 152000 miles
I have a problem with my alternator not charging battery at all.
I have already replaced it with the new alternator and same issue happens.
The red Alt light comes on (with different intensity)
sometimes it's really visible RED and sometimes it's very dim.
The car starts and runs fine.
I tried to remove positive wire from the battery while the car is running and it stops running instantly.
I have checked all fuses and they are good.
Battery seams fine since I can Charge it with my external charger.
Any Ideas?
Thanks
Alex
Oct 25, 2010 at 2:56 AM
SATURNTECH9
  • 30,869 POSTS
I would have the battery tested just to make sure it was good. Here is guide to help you do that.
here is a guide and wiring diagram (below) so you can do some testing.
and
Please let us know what happens so it will help others.
Cheers, Ken
Oct 25, 2010 at 3:19 AM
EVILPUPPETMASTER
  • 16 POSTS
Thanks for your response. I will test the battery today. I have not tested the alternator but will bring (old one) it to be tested today aswell.(old and new alt have the same simptoms)
Yes, i do have Multimeter and I can test anything you suggest.
Alex
Oct 25, 2010 at 3:29 AM
SATURNTECH9
  • 30,869 POSTS
Let's start with you testing the battery and the old alternator let me know what you find and we will go from there.
Oct 25, 2010 at 3:49 AM
EVILPUPPETMASTER
  • 16 POSTS
Well, after visiting 5 local parts stores none of them had completely working bench alternator tester.
I did test the battery and it turns out it's in perfect working order.
Is there any other way I can test this alternator in the vehicle using multimeter?
Please let me know
Thanks
Alex
Oct 29, 2010 at 1:54 AM
SATURNTECH9
  • 30,869 POSTS
Charge your battery all the way up start it up let it idle take your multimeter and check at the battery post's with it idling and see what the voltage reading is.Let me know what voltage you get.
Oct 29, 2010 at 6:17 AM
EVILPUPPETMASTER
  • 16 POSTS
Definitely not charging.
Battery is fully charged, truck is idling and I am reading 11,99 volts on the battery.
I have also measured voltage on the big positive wire on the alt and I get the same reading.
Checked all fuses and they are good
Any other ideas
Thanks
Alex
Oct 30, 2010 at 3:12 AM
SATURNTECH9
  • 30,869 POSTS
Alright here's what you need to check next the black and orange wire to the B+ terminal on the alternator should have battery voltage to it.Also check the yellow and white wire terminal A at the alternator should have battery voltage also.Let me know what you find.
Oct 30, 2010 at 4:32 AM
EVILPUPPETMASTER
  • 16 POSTS
[quote:3df98597a1="saturntech9"]Alright here's what you need to check next the black and orange wire to the B+ terminal on the alternator should have battery voltage to it.Also check the yellow and white wire terminal A at the alternator should have battery voltage also.Let me know what you find.[/quote:3df98597a1]
Yes, you are correct. When vehicle is not running it reads 12.26 v on both wires
Alex
Oct 30, 2010 at 4:53 AM
SATURNTECH9
  • 30,869 POSTS
On the alternator with the battery disconnected the two S terminal's there is a white and black wire running to those two terminal's see if those two terminals are connected from post to post.
Oct 30, 2010 at 5:50 AM
EVILPUPPETMASTER
  • 16 POSTS
ok, i disconnected positive wire from the battery, There are 3 wires on the voltage regulator, yellow/red, white/black and green there is another white wire going to another terminal. Please see picture: which wires do you want me to test do you want me to test those terminals with or without cables connected thanks for your help. Alex
https://images.2carpros.com/forum/automotive_pictures/586217_alt_1.jpg
Oct 30, 2010 at 8:55 AM
EVILPUPPETMASTER
  • 16 POSTS
I have 4.0 engine
I'll order new alt , replace it and let you knowN
Alex
Oct 31, 2010 at 1:50 AM
SATURNTECH9
  • 30,869 POSTS
I thought you already replaced the alternator?Why don't you pop that alternator off and take it to the auto part's store and have it tested you can't drive it anyways.
Oct 31, 2010 at 9:04 AM
EVILPUPPETMASTER
  • 16 POSTS
[quote:357c1e66bd="saturntech9"]I thought you already replaced the alternator?Why don't you pop that alternator off and take it to the auto part's store and have it tested you can't drive it anyways.[/quote:357c1e66bd]
I did replaced it. There is no shop in the city that has bench test for ford alternator working.
Just in case I bought another one today(also brand new) installed it and.....
It does not charge again. Same thing.
Charging light comes on and it`s reading 11.76 volts on the battery. So now I know that it`s not alternator.
This is real mystery.
What next.
Common saturntech9, we got to get to the bottom of this.
Thanks for your help
Alex
Oct 31, 2010 at 10:20 AM
EVILPUPPETMASTER
  • 16 POSTS
Any ideas where fusable links are on this vehicle
Thanks
Oct 31, 2010 at 10:39 AM
SATURNTECH9
  • 30,869 POSTS
You checked the fuse link's to the alternator already.The black and orange to the B+ terminal you said had battery voltage.Also the yellow and white wire is the other fuse link to the alternator and you said it had battery voltage.If you look at the wire diagram i sent you it show's a white and black jumper wire that run's from the two S terminal's from the pic of the alternator you posted look's like that wire all by itself is that jumper wire that goes to the voltage regulator peel the tape back and see it that wire lead's to the white and black wire to the voltage regulator connector.Remove the battery cable first then use the low ohm's setting to see if the black and white wire is connected to the wire off by itself with all the wire's discounted.Let me know what you find.
Oct 31, 2010 at 11:06 AM
EVILPUPPETMASTER
  • 16 POSTS
[quote:ae59a46da4="saturntech9"]You checked the fuse link's to the alternator already.The black and orange to the B+ terminal you said had battery voltage.Also the yellow and white wire is the other fuse link to the alternator and you said it had battery voltage.If you look at the wire diagram i sent you it show's a white and black jumper wire that run's from the two S terminal's from the pic of the alternator you posted look's like that wire all by itself is that jumper wire that goes to the voltage regulator peel the tape back and see it that wire lead's to the white and black wire to the voltage regulator connector.Remove the battery cable first then use the low ohm's setting to see if the black and white wire is connected to the wire off by itself with all the wire's discounted.Let me know what you find.[/quote:ae59a46da4]
Ok, black and white wire is connected to the wire off by itself. There is a continuity between those two.
This is driving me crazy.
Any other ideas. I am currently charging my battery.
Nov 1, 2010 at 1:56 AM
EVILPUPPETMASTER
  • 16 POSTS
another quick update,
I disconnected black/orange (b+) wire
and connected volt meter directly to the alt output.
While idling it produces, about 15-20 volts
If i increase RPM`s it gives me up to 45 volts.
When i connect black/orange wire back it gives me same
output that I have on the battery (12 volts)
yellow/white wire gives me about 2 volts less the the battery so about 10 Volts while truck is running.
When it`s not running it gives me same reading as on B+ Terminal (12 volts)
Thanks again
Nov 1, 2010 at 3:38 AM
SATURNTECH9
  • 30,869 POSTS
This is crazy you have everything your supposed to according to the diagram.You have the two power feed's and the jumper wire the only one let is the charge light wire which has nothing to do with it charging.So with all the wire's hooked up and the engine running what does the B+ read for voltage?
Nov 1, 2010 at 4:20 AM
EVILPUPPETMASTER
  • 16 POSTS
HI again,
B+ reads exactly as batterys Positive terminal. the voltage depends of charged state of my battery. When it's fully charged it reads 12.65 v. When i let the track idle for 5-10 minutes drops below 12.
charging red warrning light is on.
I do not know what to do.
Anything else you can think of
Thanks
Alex
Nov 1, 2010 at 5:06 AM
EVILPUPPETMASTER
  • 16 POSTS
hi,
i got some good news. I just cleaned small wire connector going from negative battery terminal to the frame and now started partially charging.
The red light goes on and off and i could see lights getting bright and then dim again so i will continue and clean other connections to the frame and engine.
Would you know where main frame connection is located?
Nov 1, 2010 at 7:06 AM
SATURNTECH9
  • 30,869 POSTS
That sound's promising i would think that if it was a ground issue that the starter wouldn't work.Can you post a picture of the battery cable set up?Also now that you have cleaned the cable at idle what is the battery voltage at the battery.Also try this take off the positive cable and set your ohm's meter to low scale and check the ohm's value from the alternator case to the negative battery cable.
Nov 2, 2010 at 6:23 AM
SATCHBOOGIE2U
hello, if you had vehicle running and took ground ( - ) off while running Alternator is problem... the alternator should have supplied voltage for vehicle to continue to run, so what is happening vehicle runs on battery only. there was a time you could fix alternators yourself rebuilding them and getting the parts to do so was easy, but most likely the voltage regulator on the back of your ~particular~ alternator. you may want to see if you can find a regulator for your alternator, which would save you $ if you have a little know how on vehicles ! if alternator was charging volt meter should have read no less than 12.8 volts on old, new 13.5. so take care, this test works on most vehicles! a quick check you can take a wrench and with out hitting any positive wires touch the BACK of alternator in the dead center where bearing is, if alt is charging will attract wrench like a magnet on fords & gm vehicles. have a blessed day !
Jun 12, 2019 at 3:40 AM
RONALD OLSTHOORN
  • 6 POSTS
Replaced alternator, checked all fusible links and still does not charge?
Dec 10, 2020 at 12:21 AM (Merged)
CARADIODOC
  • 34,381 POSTS
What is the symptom or test results that tell you it is not working?
Check for full battery voltage on the fat black/orange output wire and the smaller yellow/white wire. That should be on both when the engine is off.
With the ignition switch turned on, does the "battery" light on the dash turn on? If it does not, there is a break in the green/red wire or there is a blown 7.5 amp fuse. That is the turn-on signal for the voltage regulator. At the generator, you should find close to 2.0 volts on that wire when the ignition switch is on and the engine is not running. Once the engine is running, if the regulator sees output from the generator, it will put twelve volts on that green/red wire to turn the dash light off. Rather than wasting time trying to measure that, if the warning light was on, and it turns off once the engine is running, the regulator thinks the generator is working. Further proof would be to measure the white wire on the generator. That should have close to half of battery voltage, or 7.0 volts when the system is working.
If you find zero volts on the black/orange wire with the engine not running, and too-high voltage when it is running, there is a break in that wire going back to the battery. Check if there is a really large fuse bolted into the under-hood fuse box. If that is blown, it was due to the old generator or that terminal got shorted to ground, typically by bumping a wrench against it. If the fuse is not blown, check the bolts to be sure they are clean and tight. When the charging system is working properly, you must find between 13.75 and 14.75 volts at the generator's output terminal and across the battery's terminals.
RONALD OLSTHOORN
  • 6 POSTS
Thanks for the diagnosis. My reply in caps after your questions.
what is the symptom or test results that tell you it is not working?
check for full battery voltage on the fat black/orange output wire and the smaller yellow/white wire. that should be on both when the engine is off. yes it is
with the ignition switch turned on, does the "battery" light on the dash turn on? yes if it doesn't, there's a break in the green / red wire or there's a blown 7.5 amp fuse. that's the turn-on signal for the voltage regulator. at the generator, you should find close to 2.0 volts on that wire when the ignition switch is on and the engine is not running. i get one and a half volts. once the engine is running, if the regulator sees output from the generator, it will put 12 volts on that green / red wire to turn the dash light off. when running same voltage. rather than wasting time trying to measure that, if the warning light was on, and it turns off once the engine is running, the regulator thinks the generator is working. further proof would be to measure the white wire on the generator. that should have close to half of battery voltage, or 7.0 volts when the system is working. zero with igniton on and not running or when running.
if you find 0 volts on the black / orange wire with the engine not running, and too-high voltage when it's running, there's a break in that wire going back to the battery. all seems ok. check if there is a really large fuse bolted into the under-hood fuse box. if that is blown, it was due to the old generator or that terminal got shorted to ground, typically by bumping a wrench against it. if the fuse is not blown, check the bolts to be sure they're clean and tight. when the charging system is working properly, you must find between 13.75 and 14.75 volts at the generator's output terminal and across the battery's terminals.
fyi i have trued two new alternators thus far. got me stumped.
CARADIODOC
  • 34,381 POSTS
What is the voltage on the output wire when the engine is running?
Starting in the early 2000's, the engineers put an extra cover on the rear of their generators because they found them to be too easy to diagnose. If yours does not have that yet, look for the two test points on the back and measure those voltages. The right one with my nifty red arrow might have a gray plastic cap on it. That can be popped off or there will be a tiny hole in the center where you can fit the end of a straightened paper clip to take the reading. You should find twelve volts there all the time.
Before you move on to the next test, look at the black arrow in this photo and the silver button it is pointing to. Check if that is on your generator, or a wooden tooth pick, or piece of wire. I picked this photo because it shows the "nail" that holds the brushes retracted while the voltage regulator/brush assembly is being installed by the re-builder. They were supposed to remove that before testing the generator. If you see anything in that tiny hole, pull it out. You will hear two light clicks as the brushes extend to make contact.
Once that is removed, or if you do not find anything in that hole, you can move on to the next test. Check for voltage on the left test point, (blue arrow). If you find exactly the same as at the red arrow, the voltage regulator is defective. You can verify that by grounding the blue terminal. That will make the generator charge wide open, so do not raise engine speed. You will see battery voltage rise and/or the head lights will become brighter. You will hear the generator strain under the load too. Just ground that terminal long enough to get the results.
If you find zero volts at the blue test point, there is a break between the brushes. That is a typical failure at high mileage when the brushes are worn excessively, but not with a newly-rebuilt generator. I would be looking for a brush that got broken when an inexperienced person put it together and forgot to use the tooth pick to hold the brushes retracted until they were installed.
Under normal operation with the engine running, you can expect to find between roughly four and eleven volts on the blue terminal. The lower the voltage regulator pulls that down, the bigger is the difference between the two test points, the stronger is the magnetic field, and the more output current will be developed.
Tell me the voltages you find.
RONALD OLSTHOORN
  • 6 POSTS
Is there any chance the battery could be defective? I boosted the car and removed the battery cable and the engine stalled which leads me to believe it is not charging.
I cannot see the back of the alternator now that it is installed but wanted to rule the battery out first before in remove the alternator to check on your latest suggestions ( I am doubtful as this is the second new alternator).
CARADIODOC
  • 34,381 POSTS
please do not disconnect the battery when the engine is running
Every year I did a demonstration on the generator test bench for my students to show what can happen when you do that. It was real easy for the voltage to reach over 35 volts. That will destroy any computer on the vehicle, the generator's internal diodes and built-in voltage regulator, and any light bulbs that are turned on.
The thinking is that if you disconnect either cable and the engine stays running, the generator must be working but a lot of them will stop working due to the voltage regulator responding to the dips in the "ripple" voltage being produced. That will make a perfectly good generator appear to be bad so that test is not valid.
If a mechanic is caught pulling this stunt he will typically get one verbal warning. For the second offense he will be fired. It is that big a deal.
Some generators respond to the high points in the ripple. That momentary higher voltage goes right back to the field winding and creates a stronger magnetic field. That stronger electromagnet creates a higher output voltage which again creates a stronger electromagnet. It is a vicious circle and voltage can keep on rising until something gives out. The main thing that smooths out that ripple so it does not affect the voltage regulator or the generator is the battery.
Three things are needed to generate the output current. They are a magnet, (electromagnet, in this case), a coil of wire, and most importantly, movement between them. That is why the belt needs to make it spin. One thing that can save you from doing damage by removing a battery cable is not raising engine speed. Generators are relatively inefficient at low engine speeds and their output voltage is less likely to rise to dangerous levels, . . . as long as you do not raise engine speed.
One other thing to keep in mind is batteries give off explosive hydrogen gas. Regardless if your generator is working or not there is going to be a big spark when you remove a battery cable with the engine running. Either the generator's current will be recharging the battery, and that can be up to 20 amps, or the battery is going to be supplying the car's electrical systems, and that can easily be over 30 amps. That kind of current is going to create a big spark when a connection is broken or reconnected. Small arc welders run as low as 40 to 60 amps and look at the sparks they create. The reason we do not hear about more battery explosions is because people are careful to not disconnect the cables when there is current flowing through them. It is also why there are huge warning labels on all battery chargers to be sure they are turned off before connecting or disconnecting them from the battery.
Another common generator problem is one defective diode out of the six. You will lose exactly two thirds of the generator's capacity but system voltage will remain normal or it could even be just a little high from the voltage regulator responding to the greatly increased dips in the ripple voltage.
It is always a good idea to wear safety glasses when working around car batteries, but if you still insist on removing a cable while the engine is running, a face shield makes more sense, and have plenty of water on hand to wash any acid off the vehicle's paint.
Ford used to have a really nice generator design that allowed testing right on the back of the unit. Only Chrysler alternators are easier to diagnose. Unfortunately the engineers do not really care about ease of service on GM's and many other brands.
The way you tell if the charging system is working is to measure the battery voltage while the engine is running.. It must be between 13.75 and 14.75 volts. There still could be a bad diode though. You need a professional load tester to test for that. Ripple will be very high and the most output current you will get will be one third of the generator's design value. That is not enough to meet the demands of the electrical system under all conditions so the battery will have to make up the difference, until it runs down.
BOUSSE
This truck has a 3.0.
Brand new alternator brand new battery. Both tested and okay.
Battery light comes on in the dash.
Volts read twelve when running, 12.3 when off.
I have done some reading on the forums but still cannot find a solution.
Any ideas?
HMAC300
  • 48,601 POSTS
check fuse and fusible links one may be burnt out that is not supplying power to activate it. See picture these are available at auto parts and must be the same gauge.
CARADIODOC
  • 34,381 POSTS
I would try to use a small mirror to look at the back of the generator to see if that tooth pick is still in there. Next, since you cannot get to the test terminals, consider unbolting the generator so we can do some continuity tests on the work bench.
Measure between the "ground here to test" terminal, (blue arrow in my sad photo), and the twelve volt feed terminal, (red arrow). You should find very close to 4 ohms, but be aware the brushes commonly do not make a good connection when the rotor is not spinning. You may have to turn the pulley a little to get a reading.
As long as the plug is disconnected, recheck the voltage on the large black/orange wire and the yellow/white wire, but use a test light instead of a digital voltmeter. Both of these circuits are protected by fuse link wires which are just normal wires but of a small gauge. If one of those burns open, it will leave a carbon track behind where it arced inside the insulation. That carbon is more than enough to let a tiny tickle of current through that a voltmeter can see the twelve volts, but there is no way you are going to get enough current through there to run the voltage regulator. There is also no way you will get enough current through there to run a test light. That is why the test light is more accurate for this type of test.
BOUSSE
Any idea which fuse it is in the engine compartment? The fuse in the cab seems to just run the battery voltage meter. It is good.
I am checking the fuse links now.
RONALD OLSTHOORN
  • 6 POSTS
I would try to use a small mirror to look at the back of the generator to see if that tooth pick is still in there. Not there. Next, since you cannot get to the test terminals, consider unbolting the generator so we can do some continuity tests on the work bench.
Measure between the "ground here to test" terminal, (blue arrow in my sad photo), and the twelve volt feed terminal, (red arrow). You should find very close to 4 ohms, I get 2.8 OHMS. But be aware the brushes commonly do not make a good connection when the rotor is not spinning. You may have to turn the pulley a little to get a reading.
As long as the plug is disconnected, recheck the voltage on the large black/orange wire and the yellow/white wire, yellow wire will no illuminate the test light. Must be a fusible link. Have to find it? but use a test light instead of a digital voltmeter. Both of these circuits are protected by fuse link wires which are just normal wires but of a small gauge. If one of those burns open, it will leave a carbon track behind where it arced inside the insulation. That carbon is more than enough to let a tiny tickle of current through that a voltmeter can see the twelve volts, but there is no way you are going to get enough current through there to run the voltage regulator. There is also no way you will get enough current through there to run a test light. That is why the test light is more accurate for this type of test.
BOUSSE
Just green dust left in the end of the fuse links. Lol.
Thanks for the help man, I hate wiring and you saved me on this one.
How do I go about replacing these without going to a Ford dealership?
RONALD OLSTHOORN
  • 6 POSTS
I stand corrected. Both the black/orange and the yellow white, at the alternator, illuminate the test light?
Any other ideas?
HMAC300
  • 48,601 POSTS
you look at the diagram I sent and see what gauge it is then go to auto parts and buy one of comparable length and splice it in preferably by soldering it then shrink tube where you spliced it to protect it.
CARADIODOC
  • 34,381 POSTS
Next is to ground the "ground here to test" terminal while the engine is running. That bypasses the voltage regulator and makes the generator charge wide open. Do not raise engine speed because if the generator is working, system voltage can rise too high and do a lot of damage. I turn on the head lights so I can watch their brightness change, but you can do the same thing by watching a voltmeter or test light connected to the battery terminals. All generators are very inefficient at low speeds, but you still want to do this test just long enough to get the results, then you are done. This should only take a couple of seconds.
If the lights get brighter when you ground that terminal, the generator is working, (at least partially), and the voltage regulator is defective.
If there is no change when you ground that terminal, there is a bad connection on one or both brushes. There are other potential causes, but they are very uncommon. You will find worn or broken brushes 99.9 percent of the time.
RANDYRJOHNSON2002
I have an o3 ranger 4.0 that does not charge. The alternator checks out and i ran a test by grounding out the f terminal on the regulator jumpering the a term and read voltage acroos the a and s terminal connector and i had .5 on s and nothing on a
can you point me in the right direction to try next?
BMRFIXIT
  • 19,053 POSTS
1.Measure voltage between ground and generator terminal B+ (Black/Orange wire)
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_185.jpg
. If battery voltage is present, go to next step. If battery voltage is not present, repair open in Black/Orange wire between generator and battery junction box. 2.Disconnect generator 3-pin harness connector. Measure voltage between ground and generator harness connector terminal "A" (Yellow/White wire). If battery voltage is present, go to next step. If battery voltage is not present, repair circuit between battery and generator. 3.Turn ignition on. Measure voltage between ground and generator harness connector terminal "I" (Light Green/Red wire). If voltage is equal to battery voltage, go to next step. If voltage is not equal to battery voltage, repair open in Light Green/Red wire between generator connector and instrument cluster. 4.Connect generator 3-pin harness connector. Start engine and let idle. Measure voltage between positive battery terminal and generator terminal B+ (Black/Orange wire). If voltage drop is less than 0.5 volt, replace generator. If voltage drop is 0.5 volt or more, repair circuit between generator and battery.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_90.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic3_43.jpg
RONALD OLSTHOORN
  • 6 POSTS
I cannot see which terminal it is? The alternator is mounted again and your picture is not quite in focus enough?
Thanks.
