replaced all plugs, wires, coil pack, fuel injectors, had valves checked, code still says coil bad
Feb 22, 2010 at 9:54 PM
2CARPRO JACK
✓Experienced Mechanic
I have seen Fords give coil circuit codes for bad injectors, dont ask me why.If it has a misfire and you know which cylinder it is, try swapping that injector to a different cylinder to see if the misfire follows it.
Feb 23, 2010 at 12:10 AM
