2001 Ford Ranger Coil replacement, 'do it yourself' project
DOGUGOTW
  • 2001 FORD RANGER
  • 6 CYL
  • MANUAL
  • 170,000 MILES
I've been quoted about $600 to replace the coil, plugs, and plug wires. The truck is a 2nd/work vehicle with a lot of miles and I'd like to spend as little as possible to fix the problem.
Are these jobs that are difficult to do or require tons of specialized/expensive tools or are they in range for a DIYer with some basic tool (no specialized automotive tools at all)?
TIA for any tips.
Saturday, August 23rd, 2008 AT 7:39 PM
BMRFIXIT
  • 19,053 POSTS
Need tools, no tool, job can not be done.
I suggest getting the part and ask for the tools too
just the basic should be enough to get u through this project.
Not a bad job to do as a 1st
good luck
Sunday, August 24th, 2008 AT 8:28 AM
DOGUGOTW
Thanks for the reply. I guess I overstated the 'no tools' thing. I have tools, just not any specialized auto tools; screw drivers, sockets, hammers, saws, etc but on chain hoists, brake tools, or auto-mechanic wrenches with the weird angles.
Bought the part, it's held on with 3 7mm bolts ans sits right on top of the engine. Pull the plug wires, undo the bolts, reverse the process and the truck runs like new! Woot!
Thanks again.
Sunday, August 24th, 2008 AT 2:39 PM
