2002 Ford Ranger Wipers Not Working
TODDNEL
I replaced the fuse and wiper motor (which was seized) on my 2002 Ranger. Alas the wipers still do not work. Is there a wiper relay on this model and if so where the heck is it? The switch is good.
Thanks
Oct 3, 2007 at 3:08 AM
FAIRRACING31
  • 150 POSTS
Todd, your wiper relay is built in the wiper motor. Turn your key on, turn your wipers on. Check with a test light or ohm meter to see if you are getting voltage to your wiper motor. If you are not, and your sure your fuse is good, it's most likley the switch on your steering column.
Oct 7, 2007 at 10:28 AM
Suggested Repair
The wiper relay is built into the wiper motor. With the key and wipers on, check for voltage at the motor with a test light or meter. If the fuse is good and there is no voltage, the steering column wiper switch is the likely cause.
Conversation Summary
The owner of a 2002 Ford Ranger 3.0L replaced the fuse and a seized wiper motor, but the wipers still do not work and asked whether a separate relay exists. The switch was reported good. The expert said the relay is built into the motor and advised checking for voltage at the motor with the key and wipers on; if there is no voltage and the fuse is good, the steering column switch is most likely at fault.
