Spark Plug Gap
SATURNTECH9
  • 30,869 POSTS
The plug number you listed you can no longer get is a double platnuim plug thats why it ends with two P's. If the truck burned a lot of oil I would steer clear of the platnuim plugs. They carbon foul.
Wednesday, January 2nd, 2019 AT 7:54 PM (Merged)
DAVIDHAWK
  • 1999 FORD RANGER
  • MANUAL
  • 115,000 MILES
Cant get a spark plug wire off
Wednesday, January 2nd, 2019 AT 7:55 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
They make a couple of tool's to help remove them there is a plier type and a 90 degree hook tool I have seen. You could try one of those if your having a lot of trouble. You end up replacing the wire's if it's really on there I have seen wire's come apart removing them.
JUSTEND11
  • 1994 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 237,639 MILES
How far should my spark plug gap be?
MERLIN2021
  • 17,250 POSTS
3.0=.042-.046
4.0=.052-.056
KEVIY M
  • 2000 FORD RANGER
  • 6 CYL
  • 138,970 MILES
I have a 3 lt engine and the two spark plugs in the back of the engine will not turn both sides I am scared they will break off than I have trouble what can I do HELP?
BLACKOP555
  • 10,371 POSTS
Run the engine untill shes hot, then being very careful, the most careful youve ever been try to break them loose now. Should be easy. After that what you do is thread them back in and torque um down to the specs wait for the engien to cool then remove again and your good to go. Let it cool as to not screw up the threads
MMADRIDXK9917
  • 1994 FORD RANGER
Electrical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
There is no firing on two spark plugs on my truck
BLUELIGHTNIN6
  • 16,542 POSTS
Check for faulty coil pack
EICNUM
  • 1993 FORD RANGER
  • 4 CYL
  • MANUAL
  • 123,000 MILES
How do u get the last 2 plug wires off and the plugs out. Thay r under the the intake manafold next to the fire wall driver side.
WILL2689
Not as hard as they look, you need two swivals, one 10 inch or so ext.I have same truck. Take your time,
but with just those tools it is easy.
SCOOTERGPTX
Had the same problem on my 95. Finally found that using a tent stake (the hooked end) would fit in there and I got the wires off. Not what I'd call OEM, but it worked.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 FORD RANGER
  • 6 CYL
  • 40,000 MILES
2003 Ford Ranger mileage: 40,000. What is the sparkplug gap for this engine?
Wednesday, January 2nd, 2019 AT 7:56 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
Your spark plug gap should be.035.
MOSMITH
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 110,000 MILES
Sparkplug wiring sequence for 2.3 liter
Sunday, May 19th, 2019 AT 11:10 AM (Merged)
4-Cyl Firing Order: 1 3 4 2
https://www.2carpros.com/forum/automotive_pictures/12900_fo_96.jpg
