2001 Ford Ranger
FLORIDAFREAK_25
Transmission problem
2001 Ford Ranger 6 cyl Four Wheel Drive Automatic
I bought a 2001 Ford Ranger, my transfer case was gone when I bought it. How do I know which one to put back in it beacuse there are so many transfer cases that will interchange with it? My vin numer is 1FTZRI5E8IPA45798
Nov 18, 2009 at 3:05 PM
  • 110,248 POSTS
If there were different transfer cases made for the same year make and model, then you need to contact a dealer for them to identify which one you need based on the vin. Also, it should be stamped on the transder cased itself. Usually there is a steel label near where the fluid level is checked.
Dec 2, 2009 at 12:07 AM
