Idling too fast
KHLOW2008
  • 41,814 POSTS
Thank you for the input.
I did mention about the charging but did not think about checking the charging rate and you did not indicate any starting problem so it just got through.
Glad to know you have fixed the problem.
Have a nice day.
Monday, January 6th, 2020 AT 10:11 AM (Merged)
POPSWUZRITE
  • 5 POSTS
  • 1996 FORD RANGER
Engine Performance problem
1996 Ford Ranger 6 cyl Four Wheel Drive Manual
I have a 1996 ford ranger xlt, 3.0 v-6, 4x4 manual trans. Replaced motor, 129,000 miles on truck. It has high idle while driving, between gears. Any suggestions?
Check the idle air control valve, throttle position and mass airflow sensors.
DOCFIXIT
  • 18,828 POSTS
Faulty Idle Air Controler on throttle body. Remove and clean pentil and passage ways.
CJORDAN223
  • 1996 FORD RANGER
  • 6 CYL
  • 4WD
  • 210,000 MILES
My ranger has been idling high for about two months now. I took it to a mechanic who said I had two bad fuel injectors. I bought new ones and replaced them, but my idle was still at about 2500 RPM wheras normally it would be about 1300. Next I was told that it could possibly be the IAC valve and that it could be bad. So I ordered a new one and replaced it. So now I have 2 new injectors and a new IAC valve and it still idles high. Also its running alot louder, and im not sure where this comes into play but its definately noticable.
I took it to yet another mechanic, and he says its an intake manifold leak and that I should replace the gaskets. However, its only idling high when its in park and neutral, when its put into drive or reverse it drops back down to normal.
Ive also checked all the vacuum hoses for a leak and made sure there wasnt a snag on the throttle cable.
Any Suggestions? Thanks.
Check and test the throttle position and mass airflow sensor
CJORDAN223
Will do, thanks. I`ll let you know.
Also. Could it be the Intake manifold gasket? Also I have the same kind of oil leak. So could a bad intake gasket cause a leak and also make my idle high?
Vacumm leaks will cause the computer to throw fuel at it raising the idle speed also check the throttle plate could be sticking open when not suppose to.
REBELFAN83
  • 1996 FORD RANGER
  • 6 CYL
  • 199,000 MILES
I have a 96 Ranger with a 3.0 V-6.
When you crank engine initially it has high idle, no tach to see rpm but it does slow down after a minute. Just seems abnormally high. Not used to small truck engine.
Also when drive or reverse is engaged, it is a firm jar.
2CARPRO JACK
  • 11,533 POSTS
Check for vacuum leaks that will cause the high idle. Migh tbe a sticky Idle Air Control Valve. If it is idling too high it will bang into gear
