I have a 99 ford ranger 3.0 flex fuel automatic. After about five minutes of running it idles itself up to around 1500 and rarely idles back down. If it does idle back down it shuts off. At first I was thinking it was the idle control sensor causing this. Sometimes when it shuts itself off it takes 2 minutes of constant pumping and cranking to start it and struggles for about five seconds to idle. My mechanic and I put his computer on it and pulled pretty much every sensor wire off while it was running and the computer would not pick a code up. Also when attempting to restart for those couple of minutes I had 60 punds of fuel pressure and fire still no quick starting. We think its the computer bad.....What do you think?
Aug 10, 2009 at 8:12 PM
