The truck idles high & low on a cold engine. When it warms up it idles fine. What could be the problem?
Thank You!
Dec 21, 2007 at 12:07 PM
LEGITIMATE007
✓ASE Certified Mechanic
one, make sure your oil is at a proper level, and two , test your iac idle air control valve to make sure it is working properly. and then check for cracks or disconnects in you vacuum hoses.
let me know what happens
Dec 21, 2007 at 12:10 PM
NICKMOM92
MEMBER
Thanks for your reply. The vacuum hoses appear to be fine. This weekend we will be changing the oil and the idle air control valve is on order. We had already changed the throttle position sensor as someone said that could be the problem but it wasn't. The truck runs great for as many miles as it has, other than this idle problem.
Dec 28, 2007 at 9:08 AM
LEGITIMATE007
your welcome boss/ let me know what happens :wink:
Dec 31, 2007 at 8:48 AM
NICKMOM92
MEMBER
My son's truck seems to be running just fine at idle now, after changing the idle air control valve! I thank you very much for your input and so does he! Have a great day! :D
Jan 7, 2008 at 11:16 AM
LEGITIMATE007
beutifull, very glad i can help
Jan 7, 2008 at 11:28 AM
