1999 Ford Ranger no fuel
DAVID HARVEY
  • 1999 FORD RANGER
  • 4 CYL
  • MANUAL
  • 170,000 MILES
The truck simplky lost fuel and died on the open road think its fuel pump not surecheck engine light came on prior
Thursday, March 11th, 2010 AT 8:16 PM
Scan the computer for code/s and then do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Thursday, March 11th, 2010 AT 8:37 PM
